Skip to main content
Version: current
Bruteforce prevention
This example demonstrates how to protect against bruteforce attacks on the SSH port. Note that SSH allows 3 login attempts per connection, and the address lists are not cleared upon a successful login. This means you could accidentally blacklist yourself if you trigger the protection.
/ip/firewall/filter/add action=add-src-to-address-list address-list=bruteforce_blacklist address-list-timeout=1d chain=input comment="Blacklist" connection-state=new dst-port=22 protocol=tcp src-address-list=connection3
/ip/firewall/filter/add action=add-src-to-address-list address-list=connection3 address-list-timeout=1h chain=input comment="Third attempt" connection-state=new dst-port=22 protocol=tcp src-address-list=connection2
/ip/firewall/filter/add action=add-src-to-address-list address-list=connection2 address-list-timeout=15m chain=input comment="Second attempt" connection-state=new dst-port=22 protocol=tcp src-address-list=connection1
/ip/firewall/filter/add action=add-src-to-address-list address-list=connection1 address-list-timeout=5m chain=input comment="First attempt" connection-state=new dst-port=22 protocol=tcp
/ip/firewall/filter/add action=accept chain=input dst-port=22 protocol=tcp src-address-list=!bruteforce_blacklist
If all three connection lists used a 1-minute timeout, an attacker could perform 9 guesses per minute. With the structure above, the maximum is 3 guesses per 5 minutes.
warning
The address list naming follows the convention used in the Port knocking article. A similar naming scheme is used where the trusted address list is named as "secured".
